Crazy electrical
Nathanv
Kansas, USA
Hey I just did a cam and lifter replacement on my 2011 ram 1500 5.7. I had this weird electrical issues where all the relays were clicking in the tipm. No start as well but would crank when I jumped the relay. After jumping the relay multiple times and resetting the computer by touching the two battery connectors together it went away and started right up. When I went to drive I have a check engine light and it was in limp mode with a code p2017 intake runner position sensor high bank1a. I thought the sensor went bad so I replaced it and right when I plugged it in the electrical crap came back and it’s at a ram dealer and they can’t figure it out or aren’t trying I need this vehicle asap
N
Nathanv
Kansas, USA
This is a video of the electrical crap https://youtube.com/shorts/TOjN6ap63-c?si=KDu3I2DWoJAmMCme
Hagar1
Ontario Canada
2012 Ram 1500
I would start by verifying that ALL the grounds are clean and tight. Some weird stuff can happen because of a poor ground. Also, make sure the battery is good and connections are clean.
N
Nathanv
Kansas, USA
All of that has been done already grounds are fixed and battery is good.
RamDiver
Marlborough, Ontario Canada
2021 DS
What is the battery float voltage and voltage under load during starting?
These trucks are so finicky about having a good B+ voltage.
Might be worth load testing the battery with a toaster-style load tester like this $18 device from HarbourFreight.
Could you please clarify?
After bypassing the starter relay and receiving a CEL/limp mode and DTC, did you still have the relay out of circuit?
N
Nathanv
Kansas, USA
No i cranked it over by relay multiple times, and the issue randomly went away. I also had to recharge the battery because it went dead due to an aftermarket sound system that drained it hard. I had some weird issues after that but they went away until this happened with cam and lifter replacement. I put the relay back in to make sure it would crank by the key and it would I had a code p2017 with it and I think that’s why it was in limp mode but I’m just trying to get it to even start.
RamDiver
2021 DS
With that new information, I would strongly recommend that the battery be load tested first.
You need to get the truck started before you can investigate the DTCs and limp mode.
Also, how deep of a battery discharge are we speaking of?
Anything under 9.5 VDC, it's likely toast.
N
Nathanv
Kansas, USA
Completly dead I think I will have the battery replaced and get back with you this is new info to me I was suspecting a fried Tipm but I’d rather try that first the battery is the original mopar battery so might as well try
RamDiver
2021 DS
Yes, we often forget that our trucks are rolling microcomputers.
Computers are always sensitive to any imperfection in the B+ voltage.
Also, in recent years, it seems far more common to see a brand new battery with a flakey cell issue.
This fault typically remains hidden until a significant load is applied, like a starter motor.
You might consider picking up the battery load tester I linked above, to proof your new battery. I've owned one for decades.
If you consider the number of uses, it costs pennies and has mitigated enormous headaches. :cool:
The digital battery load testers are prone to false positives, whereas the toaster-style is always accurate and, with care, will last almost forever.
N
Nathanv
Kansas, USA
Also, in recent years, it seems far more common to see a brand new battery with a flakey cell.
Man I alresdy have one I farm full time the pickup is at a dealer tho 40 mins away I’ll ask if they load tested it and I’ll have it replaced anyways
RamDiver
2021 DS
I would advise caution when requesting anyone load test a battery, especially a stealership. :cool:
Most parts stores and dealerships use a digital load tester, see above comments on digital testers, but your battery may be so far gone, it won't fool the tester.
Most techs are useless without a DTC, and then half of them don't know how to properly interpret the codes.
Part swappers.
You're donating $ to have them change the battery. I understand if that's what works under the circumstances, but you could change it yourself for less and possibly choose a better battery for your needs.
N
Nathanv
Kansas, USA
I would advise caution when requesting that anyone load test a battery, especially a stealership. :cool:
Part swappers.
Well thank you for the help I’ll make sure to lyk what happens
N
Nathanv
Kansas, USA
You're most welcome.
And thank you in advance for keeping this thread updated.
That will help others with similar issues.
No problem and I would cut Man U can’t go all the way up there just to try that If they can throw one in and it works I’ll tell them I’ll put my own battery in because I do need a bigger one I have a 2k watt sound system and that’s what killed the battery before but that was before this dam and lifter failure
RamDiver
2021 DS
There are an endless number of threads on battery upgrades and battery chemistry types.
Use the search feature in the upper right corner. :cool:
N
Nathanv
Kansas, USA
I’m also thinking can a bad battery make it throw that code? P2017?
N
Nathanv
Kansas, USA
And will a bad battery cause it to go into limp mode or will that code cause it to go into limit mode caused by the battery
Ken226
Washington State
Not likely.
More likely is a pinched wire, short circuit or broken/damaged connector that was caused during the cam replacement.
Your truck is a network of several dozen computers, and when something made of cheap plastic gets damaged by an elbow resting on it, the weight of a cylinder head pushing against it or a dropped tool landing on it, **** gets wrapped around the axle.
You should resign yourself to a couple hours spent with a flashlight and mirror, inspecting everything within arms reach of that cam/lifter job.
