Custom tune DPS
Tfrizz80
I have read the site and I understand how to email diablo for a custom tune. How are you able to create your own custom tune and change your shift points and stuff like that? Is that what emailing for a custom tune is?
HemiBabe
DFW
Hmm, I'm not really sure but I bet one of the guys will answer this soon for ya
truckin151
2013 sport
To do a custom pcm tune and do it your self you need the software which is around $3000 or so. Same with custom tcm tuning. You can do some trans shift schedules on your own and some engine tuning with just the handheld though
With the email tune, you log a set of parameters that the person tuning your truck wants you to and send him the file he will then write a tune based on your log file and mods and email it back to you. Usually they can get it close in a few revisions however a dyno tune is going to be better, at a higher out of pocket cost
Tfrizz80
Tfrizz80
The trans shift and some engine tuning is what I was wanting to do. I read another post where they were changing the up and down shift rpms and I can't seem to find out where to do that kind of stuff. I had a superchip at one time that would let me do it on the hand held. Im missing something I think.
Ramunit
You are only going to get that through Superchips
glass3222
Central PA
Not true. 2005+ you can do up WOT up and down as well as Part throttle up and down with DSP. SC can do TM% that the DSP cannot do.
truckin151
2013 sport
What revision or CROM are you running? 05s can do the part throttle shifts 1-3 up and down as well as WOT shifts
Tfrizz80
Tfrizz80
Im not sure im at work right now will have to check when I get home. The hand held is model 7137.
Ramunit
05 do not have complete trans control at part thottle missing is 4up and 5dn
truckin151
2013 sport
Right, never said they did. 1-3 up and down WOT and partial. Complete trans control would be a CMR tuned trans and that would blow everything SC does out of the water. But this is an argument / discussion for another thread.
To the OP - you have the right tuner, just need to boot it up and see what version of the software its running.
Tfrizz80
Tfrizz80
Ok the version needed to be updated and I was able to change my shift points and customize like I was wanting. Thanks for the help. I didn't think about checking for updates.
truckin151
2013 sport
Yeah they have had some issues with the tune not reading quite right for the fans adjustments. Be sure you don't go to extreme on the trans adjustments and that the points make sense or you'll get a jerky ride and can do some damage.
Tfrizz80
Tfrizz80
well i used this post http://www.ramforum.com/f50/diablo-...ion-tuning-11174/?highlight=transmission+tune to set up my starting points on the trans tune now that i got my head out of my ... and updated my dsp. it does sound like a fan comes on as soon as i crank the truck. it dark so im going to have to look some more tomorrow in the daylight and see what it is. im pretty sure it the trans cooler tho. anyone know anything i might do different on the tuning from what is posted in the link?
truckin151
2013 sport
If you go off the points I posted and tweak from there you should be good, only do about a 50-100rpm at a time. Also just an fyi there is no fan on the trans cooler. Sure the AC wasn't on?
Tfrizz80
Tfrizz80
No the ac wasn't on im going to check it out more shortly. There's alot more customizing on my dsp now ... I like it! Some of the engine setting im not sure about like leaning or richening the fuel. I don't k now if there's a real good way to check this unless you are on a dyno or measuring 0-60 times. Anyone familiar with that setting?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
DO NOT touch the timing or fuel mix unless you have an A/F meter in the exhuast and a full engine system to keep an eye on knock ect. The ringlands in these trucks do not give you room for mistakes.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Before you go to much deeper pick up an AI with a Wideband setup or just two gauges like I have. Ryan is running the AI with A/F on it, Im running the AI with a AEM for the wideband. If your looking into changing your tunes up your gonna want to go cammed soon so might as well get the gauges out of the way.
Tfrizz80
Tfrizz80
Lol I have no idea what the abbreviations mean. I know when you tell me im gonna go....duh!
Fpye
