Cut it off??
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Is there any reason why I shouldn’t cut this off the frame? It annoys me looking at it since I’ve installed the new bumpers.
My fab 4's has a bracket that attaches that to the bumper, it is a quasi skid plate by itself, but you can attach a skid plate later if you chose. I guess even if you cut it you can weld something back if you want a skid plate later. It is a good jacking point as well. Other then that, cut it.
This bracket is a perfect fit to your bumper bracket, it is universal, if you want this bracket will work the same on your truck or any truck.
kurek
Northwest
Everything I've seen about it is for crash compatibility to keep yourself and others safer on the roads. It also happens to be where the OEM recovery hooks anchor, the OEM hooks are cast in such a way that they push off of it in a forward collision to maintain the frame crush zone ahead of them. Some aftermarket bumper assemblies utilize those as mounting points.
62Blazer
Midwest
Was thinking my 2500 were bolt on also?
But in any case, those are crash compatibility bars. They are meant to keep you from doing a monster truck crush if you rear end a little sports car. They are not snowplow mount brackets and they are not tie down points.
kurek
Northwest
Just for reference here is a photo of the factory tow hook mounting points (single shear bolts to bumper mounting bracket, rubber slip mount to the bottom of that frame feature) and also of an aftermarket bumper's bash plate use of the same feature as a mounting point.
diymirage
Banned
doesnt take much
a few years ago i pulled up to an intersection in bronco, only a 4 inch lift and 33inch tires
a semi came from my left and made a very wide turn, so i checked my rear view mirror and all was clear, so i backed up
i barely made it 2 feet when i heard a distinct crunching sound
turned out some joker in a honda had pulled up so close behind me he was in my blind spot
my rear bumper was inches from his windshield
luckily it was a piece a piece of crap to begin with and i didnt do much damage to it
GeauxinUp
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
That makes sense. I didn't have factory tow hooks, and I never noticed them with the OE bumper
dodgepdw
New york
Hardracer
Swfl
2010 1500 laramie 4x4 crew cab
I was gonna say the same thing as others posted...looks like where the tow hooks attach to.
WildcatHemi
Kingwood, Texas
i know this post is old. i left mine and tied in my skid plates to them. i left them cuz if/when the day comes that i sell the truck, i want to put back on stock bumper and recovery hooks.
