gruntdog
Is it common to get absolutely no help at all from a dealer that you didnt buy the truck from? I should have known when that was his first question and his whole attitude changed when I said no. Well took my truck in for popping noises in the front end. Dealer drove it around the block, pulled it in the bay and topped off my fluids and thats it in a span of about ten minutes. Could clearly hear the popping sound and they said its normal noises. Well I got home crawled underneath and my track bar was highly under torqued, sway bar mounts were same way. Now my front passenger coil spring has shifted and popping like crazy. My popping noises are gone now, Track bar torqing fixed that. Just passenger coil spring is making all kinds of noises turning. The coil itself has moved because you can feel the indentation from it on the bottom isolator. Ive ordered a new track bar from Thuren. I am done with dealing with dealers. Must be a Ram/Dodge thing because I have never had this problem with any vehicles I have had with dealers. Family drives rams and say the same thing. By the way its a 2020 Power Wagon. Just had to vent and find it very discouraging. Honestly makes me want to get rid of it.
