Decking cylinder heads
Ajwalk2008
Springfield, il
Has anyone on here done this? Been thinking about .003 off the heads to up the compression a little. Would it be worth it? What would the compression be?
charonblk07
Calgary, Ab
F1-A forged 349ci
There are several hemi builders that do it and if you don't want to go as far as doing the Eagle head swap then it's a viable alternative. While you're at it doing a port job is always a good idea. I had Inertia Motorsports do the heads on my '07 before I did the Eagle head swap.
Ajwalk2008
Ajwalk2008
Springfield, il
Eagle head swap? First I've heard of this
quietpeen
2021 TRX
Hellcat
Sorry for the stupid question....what is decking cylinder heads?
R/T_Fire
Pleasant Grove
Basically it levels the head to the block deck and shaves just a little off lessening the combustion chamber ever so slightly upping the compression ration ever so slightly.
Aside from a perfectly level surface job this can also be done with head gaskets. We would do similar things with the head gaskets on the top fuel cars depending on track conditions and elevation to raise or lower the comp ratio boost or retard performance so to say
quietpeen
2021 TRX
Hellcat
Great explanation. Thanks !!
usaf2006
North Carolina
There's a local place here that will do it for $125. Not bad for a few ponies.
R/T_Fire
Pleasant Grove
Wow that's some good numbers for the head swap...
Does it require a custom tune?
I'd say yes, but I'm sure there are people who say its not needed... but in my opinion any time you change air/fuel delivery, timing or comp ratio/ combustion volume one should re-tune a fuel injected motor. or rejet/tune a carburated motor
RonJon '06
Southern Minnesota
I was reading on the LX Forum that milling the heads .030 would take your CR from 9.6:1 to about 10.3:1 so milling them .003 would get you less than 9.7:1. When I had my heads resurfaced at the shop I think they shaved off .003-.005.
Ajwalk2008
Ajwalk2008
Springfield, il
So basically it wouldn't be worth it doing .003. If you did .030 you would have to do that much shorter on the push rods right?
charonblk07
Calgary, Ab
F1-A forged 349ci
when you go that much you should measure the required pushrod length, assuming the length because of a shorter head height might get you close but you may still be too short/long. Places like Trend have length checkers for $30 and .080 wall forged rods are like $5 each. Trend also has lengths in .025 increments where Comp only has .050 lengths
BoBoway4
