Dee Zee Tailgate Assist
RichStevenson
Medina. Ohio
I just installed the tailgate assist, and was wondering if it's operating the same for those of you that have it installed. When I open the tailgate, it drops fast for a few inches before the assist catches. Is that normal?
aldosterone
Mine drops slowly almost from the beginning. Let it settle in and see what happens. Could always ask for a new small piston part from them.
JOHRY
Ontario, Canada
EcoDiesel 3.0
Yeah mine does the same thing. It's due to the angle of the catch point. Basically the support doesn't actually grab for the first few inches of travel.
RichStevenson
RichStevenson
Medina. Ohio
Well ****. Looks like I put the piston in upside down. When the instructions said attach the larger part of the shock, I took that to mean the larger part of the piston where the cap is. That cap is what made me think that was the larger part. I looked up pictures and videos, and noticed everyone else's was installed opposite of mine. So I just flipped it around, and it catches much earlier now.
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Well damn... Glad you posted! I though the initial drop was normal... I flipped mine around and now it catches as soon as you open and let go!
Outbreak
Cummins 6.7
Mine is slow the entire way, but it looks like you figured out what was wrong.
I'd post a pic of mine, but it's a few thousand miles away...
grizzstang
Calgary, Alberta Canada
Both those are right and I believe the instructions tell you to connect the top first then the bottom but I found I could not get the bottom on with the top connected as the shock would hit the truck. Connect the bottom first then the top.
1500canoe
Central Pennsylvania
Yep, same here.
Gixxer4915
Connecticut
Mine does the same thing. I use to own a Nissan Titan that had a factory one. Titan goes slow right from beginning.
Michael Cole
Maryland
Checked mine and the install is correct but the shock also holds the tail gate ( left side ) and not the cable. The right side ( passenger side ) cable holds the tail gate. Any thoughts ?
