Diablo i3
SD2020
Canada
I thought I would do a quick post.
My 2011 and the Diablo i3. I had the idle drop issue, no matter where I set the idle to be at. It took many emails but after many tests with them, they were able to give me a custom map. It has been working properly now for the past several weeks. Just an option for folks that may have had the same problem.
S
SD2020
Canada
I hate my diablo tuner If i didnt pay $300 for it 2 years ago i would never use it lol.
Ya they are awkward for sure. I just wanted to fix idle, tire size, and turn off MDS. Then I ended up getting a HF tune.................. but it had some issues in itself. So I was stuck with a horrible resonance HF tune, or a Diablo tune that idle dropped. At least with tweaked Diablo tune, I can throw a Borla pro XS or Dynomax ultra flo on it now. The HF tune, with the 5 speed to 6 speed change, is pretty hard on fuel in town, holds gear way too long, I need to see if he has a 5 speed tune for the 545rfe, and run a datalog on the Diablo tune to try and see the difference between them. If both the DIablo tune and HF tune are "safe", afr wise, i'm not sure how such a small tweak in that ratio can send the resonance into chaos, unless its a timing change that is doing it?
If i was anticipating these issues, I would have gone 100 percent with HP.
DripJust
Canada Ontario
Anyone had any experience adjusting spark timing on a 87 tune with the diablo I3 ?
