Diablo sucks it...
Jmhm17
Massachusetts
5.7L HEMI
wont the 4.10's make you smoke em even more? I'm sure the LSD will help but still your going to get faster torque. Ill be happy if I can one tire fire through half a gear with my 3.55's after this tune hahaha
DavidRam
SoCal - Redondo Beach
2012 RCSB
The LSD will help me smoke BOTH tires evenly! Lol!
DavidRam
2012 RCSB
Had the same problem until I dropped it and added the KDW's if you can get some of those tires I highly recommend them.
I'm headed out now to get some log time.
KDW's just added to the list.
This week is 4.10 and lsd install. Hopefully next week I can get the drop installed.
Jmhm17
Massachusetts
5.7L HEMI
holy crap, no way is that just a tune.. you have every bolt on, your picking up your drivetrain loss and then some. MOD LIST PLEASE lol
blackout11
alpharetts GA
2011 R/T
Lol well his tune gave me an extra 50 h/p acording to hemi fever and i can take a pic of me holding it up next to truck
as far as mods got a cut out varram intake throttle body 87mm e fan custom hemi fever tune throttle body booster 180 therm thats about it for engine oh ya custom bent 2 3/4 exhaust with magnaflow no res and 5'' tips
Jmhm17
Massachusetts
5.7L HEMI
thats impressive.. i didnt think you would get over 360 with those mods to be honest.. What do these trucks do stock?
Jmhm17
Massachusetts
5.7L HEMI
Yeah crank is crap, what do these things do baseline on a dyno
blackout11
alpharetts GA
2011 R/T
around 300HP from what I read..
50HP from a tune.. I dunno..
Was this a mustang dyno or Dynojet?
since i have no idea it was a heres my keys drive it on dyno hook it up and go dyno and thats what sean said he can get to the 11's an extra 50
was a free dyno day for my girlfriend club they let me do my truck just to see what i could get
Jmhm17
Massachusetts
5.7L HEMI
I should do a baseline but all I have around me is a Mustang Dyno so my numbers will not please any dyno queen gods around these parts lol. i feel I'd be lucky to break 300 on a mustang dyno..
blackout11
alpharetts GA
2011 R/T
whats the difference on dynos im pretty sure they have the best one since they build race cars they build 9 secs caddies and vetts
they have a dyno jet just called them
Jmhm17
Massachusetts
5.7L HEMI
A mustang dyno is load bearing, meaning its actual on the road horsepower with the weight of your truck included. where as dyno jets just use a free rolling roller, i dont know if they calculate vehicle weight or not, but a dyno jet will always read higher as its not "real world" HP. also Mustang dynos are better to tune on especialy boosted cars where load comes into play to dial in AFRs
BlownGP
Houston/Baton Rouge
Dynojets will usually show more.
Here's a good read on both.
DynoJets are inertia dynos, and have been around for years, much longer than any type of load cell dyno. Inertia dyno's work on the principle of the acceleration of a known mass over time. Their rollers are the known mass. Weighing in at over 2500lbs or so. Your car gets strapped down to the machine, and the dyno collects it's data. It is able to calculate horsepower by measuring the acceleration in rpm of the rollers in regards to RPM. This is why gearing can affect the dyno results, more on that in a bit. Now that the dyno has recorded the horsepower curve, it can take the integral of that curve and get the torque curve. Since the dyno’s power calculations are based on the acceleration of mass over time in regards to RPM, gearing is very important. Since a vehicle with a lower gear ratio can accelerate the mass to a higher speed using less engine RPM, it will show a higher horsepower number than a car with a higher gear ratio. If a car is able to accelerate the dyno’s rollers from 200rpm (roller) to 300rpm (roller)in 1500rpm (engine), then the dyno is going to record more power than a car that did that in 2000rpm (engine).
Now we go to Mustang dyno’s and other loaded dyno’s. Our Mustang MD-1100SE dyno’s rollers weigh 2560lbs. That is the actual mass of the rollers, much like the DynoJet. That’s about where all the similarities end. When we get a car on our dyno, we enter two constants for the dyno’s algorithms. One being the vehicle weight, the other being what’s called “Horsepower At 50mph”. This is a number that represents how much horsepower it takes for the vehicle to push the air to maintain 50mph. This is used as the aerodynamic force. Mustang dyno’s are also equipped with a eddy currant load cell. Think of a magnetic brake from a freight train. This magnetic brake can apply enough resistance to stall a big rig. Off one side of the eddy currant load cell, there is a cantilever with a 5volt reference load sensor (strain gage). As the rollers are spinning this load sensor is measuring the actual torque being applied. So as the rollers spin, the load sensor is measuring the force being applied, sending that information to the dyno computer, taking into account the two constants entered earlier, computing the amount of resistance needed to be applied to the rollers to load the car so that the force of the rollers resistance is as close to the force the car sees on the street. The dyno is then able to calculate the total force being applied to the rollers in torque, and then taking the derivative of that torque curve to arrive at the horsepower curve. Since torque is an actual force of nature, like gravity and electricity, it can be directly measured. Horsepower is an idea that was thought up by man, and cannot be directly measured, only calculated.
I like to state it like this. . . I start by asking how much your car weighs, lets say 3500lbs. Now you take your car and you make a make a WOT rip in your tallest non overdrive gear, how much mass is your engine working against? 3500lbs right? Now you strap your car on a DynoJet and you make a WOT in the same gear, how much mass is your engine working against? 2500lbs right? Now you strap your car on a Mustang dyno, how much mass is your engine working against? 2500lbs. Plus the resistance being applied by the eddy current generator. We’ve seen anywhere for 470lbs of resistance to over 700lbs of resistance as measured in PAU force in the data logs. So which one is more accurate? Well they their both accurate. If a DynoJet dyno says you made 460rwhp, then you made 460rwhp. If a Mustang dyno says you made 460rwhp, you also made 460rwhp. Now which one of those numbers best represents what your car is doing when its on the street. That’s a different question.
The most important thing to remember is that a dyno is a testing tool. If the numbers keep increasing, then you’re doing the right thing. We try to look over at NET gain, instead of Peak HP numbers. A 30rwhp increase is a 30rwhp increase regardless of what dyno it is on.
Now I can address how to calculate the difference between one type of dyno and another. Simply put, you can’t. Because Mustang dyno’s have so many more variables, it’s not a simple percentage difference. We’ve had cars that made 422rwhp on our Dyno, two days later make 458rwhp on a DynoJet the next day. We’ve also had cars that made 550rwhp on our dyno, make 650+rwhp on a DynoJet a few days later at another shops Dyno Day. For instance, my 2002 Z28 with a forged internal LS6 Heads/Cam/Intake, makes 460rwhp on our dyno. I thought that was a little low, since I’ve had cam only LS6 Z06 vettes make 450rwhp. So I overlaid the dyno graphs. Guess what, the PAU force for my car was almost 200lbs more than the C5Z06 that made 450rwhp with cam only. So I entered the weight and horsepower at 50 number for a C5Z06 and did another horsepower rip with my car. The only reason I did that was to compare Apples to Apples. This time my car made 490rwhp, no other changes. Now I don’t go around saying my car made 490rwhp, I say what it actually did with the correct information entered into the computer. It made 460rwhp. Now if I ever get a chance to take it on a DynoJet (which I plan to in the spring), I have no doubts it’ll be over 500rwhp. I know this based on airflow and fuel consumption on the data logs.
But since we’re asked this question constantly we're fairly conservative, and hence tell our customers that the difference is closer to 6-7%, but as you make more power, and the more your car weighs, the difference increases as well. You must remember, Dyno's regardless of the type are tuning tools, and are in no means meant to tell people how fast their car is. Now which one is more "real world" is a totally different question. I like to explain it like this..... If you drive your car in a situation in which you have no mass and you're in a vacuum, so basically if you do intergalactic racing in space, use a DynoJet. If your car sees gravity, and has an aerodynamic coefficient, and you race on a planet called Earth, then use a Mustang Dyno
BlackRamHemi
Edmonton Alberta Canada
Dyno Schmyno!
I ran high 13's NA at the track with just 317HP/347TQ
I think Ethan (Grey Chevy) did 12.8's with about 330WHP
With those numbers well into the 400's
you should be throwing down low 12's or high 11's at a quarter mile track.
Track Slips or **** :signs8:
:D
Jmhm17
Massachusetts
5.7L HEMI
yeah that dyno sheet shows some serious horsepower. And that better be with the motor in the truck haha
