Diablo Tuner: 92oct on 93 tune?
WulfGang
PA
So I went to fill up my tank today because I had a nice discount at $.70 off per gallon.
Ran the card, went to choose the octane and lo & behold, the highest oct available was 92 oct.
I have my DS T1000 set to a 93oct perf tune.
I'm about to tow a bit and am wondering if I can run the 93oct tune SAFELY?
WulfGang
WulfGang
PA
well
guess there's only one way to find out
let you know how it goes
popcenator
Omaha, NE
You just have to monitor long term and short term knock. Neither are good, but long term is worse.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Its never recommended to run a lower octane fuel than the tune calls for, but your computer is programmed to pull timing if it senses any knock from the lower grade fuel. If it were me, I would step down to a lower tune. A lower octane tune with proper octane fuel will actually make more power than a higher octane tune with lower octane fuel.
WulfGang
WulfGang
PA
Thanx for the input guys.
I ended up running the 93 tune haha.
The truck ran real strong with no audible or noticeable differences other than THIS TIME that I towed, I was using the HemiFever tranny tune.
Truck pulled great. Shift points were perfect. I never even had to turn OD off or Tow/Haul it.
