DIY: 2013-18 (19 classic) Power Fold Mirror upgrade/Notes
chrisbh17
FYI - these mirror part numbers are from a 2018 RAM 2500 Harvest Edition. They are chrome capped:
Left - 68338375AD
Right - 68231242AJ
Based on the RAM pocket guide and a ton of pictures from the seller (before I purchased), they have the "full boat" of features, except since the Harvest does not come with memory anything, RAM lists them as not memory or auto-tilt-in-reverse capable.
However, they are. I put them on my '17 1500 Big Horn and now have auto-tilt-in-reverse (no memory for me, since I dont have the memory seats or modules)
Just another set to add to the part numbers, maybe. They are harder to find, but might come cheaper since they arent off a Laramie/Limited.
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Left - 68338375AD
Right - 68231242AJ
Since the Right - 68231242AJ , matches my factory 18 LARAMIE 1500, I assume these are Standard size 1500 pwr fold mirrors ... not tow mirrors? And they both AutoDim?
M² Mods.
chrisbh17
They are both standard size, I will verify auto dim tomorrow (I had sent the part numbers to Benny but he was not sure if the right side auto-dimmed and all of the RAM paperwork and specs are unclear on that fact)
Now that I know what to look for (thicker rim around the glass) Ill be able to tell for sure.
Mpgrimm2
Mpgrimm2
SC
5.7L
Right side should be AutoDim since it matches my factory 18 Laramie passenger side mirror PN.
M² Mods.
chrisbh17
The interesting part is the MSRP of the left side mirror.
$222.00.
vs 600+ for the right side.....
Mega Man
Littleton, Colorado
For the record, unless anything has changed for 2017-2019 ( I don't think it has
) no tow mirrors are auto dimm. I know there are no aftermarket versions
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2
Mpgrimm2
SC
5.7L
Some troubleshooting notes to keep an eye on getting the AlfaOBD thread ...
Ok guys. So still having trouble with my friends tow mirror install on his 2013 1500 tradesman. Used alfaobd to turn on the tow mirrors present, approach lights, and turn signals. Everything works but the approach lights. Took it to the dealership last week to get a recall fixed. The service guy told him the computer was shutting the approach light due to not recognizing led voltage. (Not sure if that is exactly right) he tried to get more info from the guy but the service tech told him it would need to be put on the computer and cost him more money to get more info. I'm stuck on what to do next. Any help is greatly appreciated.
Are they aftermarket mirrors? If so, there are a few Chinese manufacturers that reverse the leads for the LED's. I had a set of YITAMOTOR mirrors where the wires on the second (white ) connector had to be reversed to get the light to work. The wires were REd and BLUE IIRC.
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
The following info confirmed. Tow Mirror Post 3 updated....
Black textured Plastic Power fold AutoDim TOW Mirrors with MEMORY
2017 3500 Laramie VIN: 3C6UR5NL0HG781561
... Build sheet ....
http://www.ramtrucks.com/webse...tServlet?vin=3C6UR5NL0HG781561
Following PNs verified for the above VIN by AllMoparParts.com (Benny)...
Pwr Fold, Heated, AutoDim w/o color w/puddle/signal & MEMORY
(Confirmed from build sheet & Benny):
(R) Pass Mirror: 68412884AA
(L) Drvr Mirror: 68412885AA
M² Mods.
Lawsuit11
Westland, MI
So with the autodim is it just the glass itself that is different on the passenger side. I found the passenger side glass that is auto dim Incase anyone wants to upgrade their passenger side with auto dim if possible. This is only for standard mirrors not Tow. It’s a bit pricey but it’s an option
Auto Dim glass passenger side 6x9 - PN - 68079362AA
When I get my color matched mirrors of the passenger isn’t auto dim I’ll probably invest in the glass.
Mpgrimm2
Mpgrimm2
SC
5.7L
You will likely need to run the wires from the mirror glass back through the housing to the mirror connector
M² Mods.
skuppy069
canada alberta
2018 1500 cc
Anybody know if the 2019 mirrors will fit on the 2018 trucks ?
I’m trying to think about adding the blind spot Mirrors possibly and then using a after market kit to trigger the light in the Mirror .
datammwv
Parkersburg WV
2018 & 2017 2500
Looking for information on how many wires should be on WHITE plug from mirrors if power? (4) Then on Black one (8)?
Ordered power folding mirrors and from what I see are same as what I have in non power folding mirrors.
Yes I have change to 68225102ac & 68225013ac plug Door switch. And change in software.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
I'm in the process of relocating and never saw this threaD till just now. Here goes some more $ for a cool mod, :33:.
Thank you @Mpgrimm2 :cheers:
Mpgrimm2
Mpgrimm2
SC
5.7L
Schematic for 2018 Laramie 1500 and connector info attached to assist.
Door Module Connectors C1 & C2 are from the Mirrors (Couldn't upload C5)
  • 18Laramie1500 MIRRORS---EXTERIOR---PREMIUM.pdf
  • 18Ram1500 Module-Door-Driver-C1.pdf
  • 18Ram1500 Module-Door-Driver-C2.pdf
  • 18Ram1500 Module-Door-Driver-C3.pdf
  • 18Ram1500 Module-Door-Driver-C4.pdf
Mpgrimm2
Mpgrimm2
SC
5.7L
Thanks to Remen for the confirmation...
Sure Mike,
Same as post 3 on your link but no auto dim on
(R) Pass Mirror: 68412880AA
Same options but with auto dim
(L) Drvr Mirror: 68412883AA
Re
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
Thanks CincyCuda68
I don’t have the rear view dim mirror (yet) so I don’t know about the dimming, I also don’t have memory seats but I ordered memory mirrors in case I upgrade in the future.
Part Number
68225102AC Module-Door
68225103AC Module-Door
56046826AE Window Switch
68412884AA Power Mirror
68412885AA Power Mirror
The tilt in reverse works with these as well, I thought it only worked with the chrome but I was wrong!
skyline090
charlotte, nc
Thanks for all this info. It's certainly helpful.
I'm buying a pair of used OEM power folding/turn lamp standard non-tow mirrors off a 2017 1500 to replace my standard power/heated only mirrors off my 2015 1500. Are the just the mirrors themselves a direct swap? I still need to get the switch and door modules but I want to ensure fitment of the mirrors. Thanks!!
Sent from my SM-G965U using Tapatalk
Mpgrimm2
Mpgrimm2
SC
5.7L
Yep direct fit. If you have AlfaOBD, you can read out the module PNs in the doors to see what you have but likely you will need new modules and definitely the correct switch.
M² Mods.
skyline090
charlotte, nc
M² Mods.
Thanks! The obd mx connector is next to purchase as I realize how badass it is now. I also scored a complete NIB oem remote start kit for almost nothing. I need to read up on how to program that as well.
kirraweemufflers
