Drive it a while. Its a comm loss code. It should go away.Did the swap today.. everything works but now have a check engine light.. anyone else have this problem?
I did a reset of my 8.4 once I got the factory bezel wired. Now mine displays the turns in the cluster as well.Never was able to find the option for turn-by-turn option in the cluster on my RA4. Figured I was out of luck. Was driving today and used the navigation and guess what pops up in my cluster. Guess this answers my question of whether or not it worked.View attachment 49403
-JT
Ok, I just noticed something that may point to a faulty radio. If I'm not mistaken your "total unit count" during flashing is 11. I believe it is supposed to be 12 on both the RA3 and RA4. This would point to a faulty module within the 8.4 hardware itself.I got the firmware right from uconnect site. The main issue I have that the 15.6.1 firmware is supposed to fix is that when listening to FM or XM radio.. it will randomly switch to AM at times for no reason. No worries though.. I'll get it figured out.
The total unit count on my 2013 RA3 is 12 when flashing.
The total unit count on my 2014 RA4 is 12 when flashing.
Unless the consolidated 2 of the modules for the 2015 units I believe this is your issue. The firmware is an all or nothing update.
I've had different numbers of units being flashed when I factory flashed mine before.
One time I only had 4 units and another 11.
When I installed the Customtronix flash is only updated 3 units.
The firmware flash is not an all or nothing flash nor are they complete firmware packages. They only update the units that are intended for that particular release. I have also seen as Cgerorgemo different counts with different versions.
I believe you are correct. Harman hardware and QNX software/firmware.If I'm not mistaken it runs QNX.
Well LKQ ****** up and send me a CD player and not a radio.![]()
This is mentioned alot when people buy from LKQ.
