Do headers make a ticking noise
justadodgeman
west virginia
Seems like it's coming from around the collector but it's welded to the y-pipe and no leaks so do headers just make a ticking noise. I used mopar gaskets and tightened them up good. Haven't tightened them after a heat cycle or after over 1000 miles haha but I didn't feel any leaks around the gaskets.
charonblk07
Calgary, Ab
F1-A forged 349ci
The stock cast manifolds attenuate a lot of the valve noise, when you swap to tube headers they will have a higher noise transfer since there is less material.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I would use a rubber hose to listen closely around the collector area. Sometimes the headers have leaks from the factory.
R/T_Fire
Pleasant Grove
Mechanics-Stethoscope can locate alot of sounds...
http://www.amazon.com/Lisle-52500-Mechanics-Stethoscope/dp/B0002SQYSM
But as charonblk07 said, you will get a different tone and resonance of valve train and injector noise with tube headers.. Think of it this way, the cast manifolds act the same way as a magnet on a cymbal on a set of drums... change the size of the magnet and the tone changes... its a crappy example but best I could think of
