dodge ram 5.7 hemi starting problem
billybutler
went out today to pick up some gear and it wouldnt start on return ,battery is good turned over fast but struggled to fire, first problem since new 2004 help
BigSloth
Mobile, AL
2014 1500 CCSB Black Express
Any codes? by struggled to fire, what exactly was it doing? Could you hear ignition, like it was trying to start but it's out of gas, or it just took a long time then started normally?
Mjonez23
I have been having a similar issue recently. Some times it will take a full 6 to 7 seconds for engine to start. Definitely not a fuel pump issue because I can smell the gas. Maybe ignition related? Curious if others have had this issue.
BigSloth
Mobile, AL
It can still be a fuel pump issue even if you smell the gas. They need fuel pressure, not just fuel. If the pump is not creating adequate pressure, then there can be issues associated with that. The only way to know would be to use a fuel pressure gauge to get a reading KOEO, and then at idle, then under load.
Ignition problem is possible as well, though not in the conventional sense. Extended cranking time can usually be attributed to either fuel pressure, or a crank or cam sensor problem.
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
+1 on a possible Fuel Pump.
Also make sure you check the grounds to the chassis and leads in and out of the IPDM (fuse box under the hood on the driver side).
Faulty grounds or power leads could impair sensor readings as well as firing signals from the PCM to the coil packs.
Just another thought.
noraa73
