SCMortgageMan
Need some help here...
One other quick thing, did you guys have a small hole in the two corners closet to the engine (not on the two corners against the side of truck)?
I couldn't figure out what those were and wasn't sure if they were maybe there for drainage or something??
Yes, there are four holes in the bottom. Two of them have bolts that run down in to the fender well where they are held on with washer and lock nut.
The other two holes (one in each of the corners closest to the engine) are the ones in question.
I'm assuming you mean a gap?One other quick thing, did you guys have a small hole in the two corners closet to the engine (not on the two corners against the side of truck)?
