doing the cam and lifter swap a few questions?
stillrunnin
maryland
first having trouble getting fan to break loose . i have changed many a water pump and this one is tight i might have to break down and buy the tool to hold pulley . and second i cant find much info on how to remove intake manifold. any help would be appreciated
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Air hammer for left-hand thread on the clutch fan.
What replacement cam and lifters?
Friednice
Raincity
5.7L hemispherical combustion chamber
Yes sir there is a kit that works with the air hammer to break loose that stubborn fan. Works every time, even better with the snap on air hammer :893karatesmiley-thu
intake manifold is a few bolts going to the head the quick connect for the fuel rail and few electrical connectors
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Some auto stores rent out tools. Actually free, you pay a deposit & then you get it back when you bring the tool back. Hope they have what you need.
jws123
nj
Idk what year yours is or if it changes but the tread on my 2011 was reverse spin it clockwise to get it off. ALSO if you give the fk up cause its still stuck like mine was it is 100% possible to take the pump and fan off together.
S
stillrunnin
maryland
just figured that out today my luck i had a pipe on it .then i said lets try the other way and i got it .i am down to heads got pushrods out now to take exhaust manifolds off any tricks?
LeesEvoX
Houston, TX
Hemi 6.4l
Grease up your knuckles. Lol.
Exhaust manifolds are easy to get too from the fenders. If you have 4wd, maybe a little worse. I have 2wd, and just had to remove the dipstick tube to get the drivers manifold off
Sent from my SM-G950U using Tapatalk
S
stillrunnin
maryland
Got down to lifter the bad one is stuck any tips I guess I could take cam out and push it down that way
mvm2
