Dome Light Question??
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
I have only ONE dome light in my 2017 Tradesman and it IS NOT a "push/turn on"... it is fixed...
I don't know the correct way to remove the cover to put in a hyper-spiritual LED
Anyone else have one of these FIXED dome lights?
Does it just "hinge" down like the push-button ones do??? cuz I tried that and it seems to be locked in on the sides too...
THNX again ahead of time
(anyone know of the mack-daddy LED to install there since it's my only light)
gypsy400
Take a small screwdriver and pry where that slot is.. it hinges down
Sent from my SM-G960W using Tapatalk
joelmic
joelmic
stl mo
OKAY, i used some plastic trim tools but YES gypsy is right, it does still hinge down from the 'slot' side... BUT, I had to start my tool on the side of the lens... work my way to the 'slot' area. Notice the 'slot' is NOT the only locking point... it has 3 in that area!!!
So once opened, I used a spare LED I had from my 2007 and it worked fine...
It was harder getting it to snap back in than it was to take out!!!
stimpy433
IOWA
What size bulb is that? I'm having a hard time figuring out what size my 2013 Tradesman takes.
It's a 41mm HP6 LED bulb, that's what I installed in my truck this summer. I got mine from Diode Dynamics.
