Driver read door electrical issues
gersti
5.9L Cummins Turbo Diesel
New forum user here... I have an '05 2500 4x4. I Recently lost control of the power window on the rear driver side door. I verified the motor, it runs fine and opens and closes the window when using jumpers to supply power to the motor directly. Verified window door switch as well but didn't probe further yet. Now the same door power lock stopped working. It's time to start getting serious now. I am starting suspect the wiring harness. Are there any wiring diagrams available online somewhere? I looked but not finding what I need. Thanks.
MarkV
Ontario, Canada
4.7 Magnum V8 NOW with Moose Power
It is probably the wire as it goes from the door to the cab body. Inside the rubber sleeve the wire tends to brake the wire from opening and closing the door.. So you need to pull back the rubber sleeve and just color match the wires.
