E fan setting
jay c
jay c
Las Vegas, Nv
I'm not sure if you can set it or not. Just give HemiFever an email, I'm sure he will let you know about that.
Thanks again for responding, as you probably guessed even with the t stat hole at 12 the truck only drops down to 183, so once the fan comes on it doesn't turn off. I just sent Sean an email hopefully I get a fix for this.
jay c
jay c
Las Vegas, Nv
In case someone is reading this thread and wondering if you can change the setting, Sean @ hemifever told me you can set the off e fan temp yourself. I'm assuming it's the AC off tab on the trinity.
jay c
jay c
Las Vegas, Nv
Ok last post about this e fan. It turns out hemifever can't change the settings for the off settings he had me contact DS customer service. I didn't need to tho because I took my t sat out and noticed the hole was at a 9 o'clock position moved it to the 12 o'clock and everything is good now.
Some things to take away is that the e fan is set to shut off at 183 not 180 if it matters to anyone. Also, when I took out my jet t stat I noticed the seal had shrunk and had gotten hard I could spin the stat while it was in. I still have my stock stat so I swapped seals and now it fits nice and snug in the indentation. Don't know if it is or can be and issue, but just wanted to share.
joshhhh
