E-Fan?
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Anyone done an E-fan on they're 4th gen yet?
I have 2 extra fans in my garage so I'm thinking of tackling this idea. Just need to order that fan controller again from DCC.
autobred
southern md
sold* 10' R/T..13' R/T
our gen 4 has an e-fan installed from the factory. If you decide to take off the clutch fan. The factory setting for the e-fan to come on is 222 degrees. It can be reset with a tuner though, superchips or diablo to come on sooner depending on what tstat youre running.
shadow11
Banned
Houston TX
Your truck really has a electric fan? Can you take some pics please
autobred
southern md
Caleb, you have a gen 4 right? Step up on your front bumper and look over. It sits approx 4" behind the clutch fan, bolted on to the radiator. Approx. the same diameter as the clutch fan. No wiring needed, just reset fan setting thru a tuner.
shadow11
Banned
Houston TX
Yep we have a 4th gen. I can't believe i haven't noticed the efan. I'm going to go look right now
shadow11
Banned
Houston TX
Couple pics I just took. Isn't that fan just for when the ac is on?
autobred
southern md
if you have a tuner, it can be reset. From the factory its set at 222 degrees. Diablo:
you will see two tabs:
Top tab is Cooling Fans AC Off, click on it
sub tab:
High MPH HS FAN ON 222.79 degrees is default value
Low MPH HS FAN ON 222.79 "" ""
all that means is below 8 mph or above 8 mph per their website
Go back to the orginial two fan tabs:
Lower tab is Cooling Fans AC on, click on it
only one sub tab:
It reads like this on my diablo tuner
Im running a 180 tstat so I will set all my values at approx 185 degrees. Just waiting for my summit pulley come in to do that at the same time. When you take the clutch fan off, the bottom of the shroud actually drops out, (2 piece) so the clutch fan can slide out from the bottom in one piece (clutch, fan) Removing the clutch fan Bolt, facing the engine, mount the spanner wrench at (Alternator side) to turn clockwise to loosen. Its left handed thread.
RubberFrog
That little fan isn't going to be enough. It's just to supplement the clutch fan at idle.
The good news is that you can probably wire in a bigger fan and use the factory controls.
shadow11
Banned
Houston TX
Damn, mine isn't an efan. Looks like I'll be replacing the clutch fan.
Yes you do have an efan. You have to climb up on the engine and look about 5-6in in front of the clutch fan and you will see it.
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
Trup you 100% have an e-fan on there as well. There are a number of people on another forum (that you just joined) that are running only the e-fan with the settings changed and a 180 t-stat with no problems.
RubberFrog
That's good to know for my next truck. Anybody towing like that?
Trupiano
Trupiano
Registered User
6.7L CTD
I absoultely love your truck RubberFrog! It's awesome! But r u thinking of getting a 4th gen?
Hmmm... I just might try that then. But then again, that electric fan did seem pretty small. And there's no way in hell I'm gonna let this thing overheat! I'll have to do some experimenting in the summertime.
