sportsman70003
Working on a 2003 Dodge 1500 that has some kinda electrical issue. The truck has been worked on by 2 or 3 others pervious to me. The little red dot on the right side of the instrument panel is blinking and when you turn on the ignition switch on with the key the instrument panel does not come on. The radio makes a noise but does not come on either. Here are some weird things I've found. All the windows roll up and down with the ignition switch off. Also if you have the windshield wipers on and push in on the key with the switch off the windshield wiper come on. I'm leaning toward maybe a bad ignition switch but want to ask you guys first if anyone has seen this problem or if mabe there is a test I can perform on the ignition switch.
