Electrical Issues
Blandd
San Antonio, TX
6.4L
I have a 2016 Ram 2500 with the 6.4L. I bought it a year ago in April A few days after I bought it, the battery died. Dodge replaced the battery no questions asked. Here I am a year later, similar thing, slow to start, the no start. I've jumped started it and let it charge and as soon as I shut it off, its dead again.
Has anyone else experienced anything like this?
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Does the truck sit for long periods?
Did you or the previous owner install any aftermarket equipment that would possibly draw static current?
tron67j
Maryland
First thing is check alternator, could be the problem. Second thing is the battery, when drained, needs a good slow charge. Put a battery charger on it for a day or so at low amp setting. You could also have something drawing power when off, only real way to find that is to test all connections at fuse block with key off, also could pull fuses one at a time at night and replace in morning. Once truck does not start, you found it. Maybe someone else will have a better answer, good luck.
B
Blandd
San Antonio, TX
6.4L
Truck never sits. it's an every day driver. I thought it was the alternator as well, it appears to be holding a charge but as soon as I shut it off, it won't start again... hmmmmmm
Thanks for the advice, I'll check it out tomorrow.
WoodGuy
St George Utah
Never had a OEM battery last more than 2 years myself. If you have a volt meter, check it at the battery with the truck running and you should see 13.6-14.7. If you do, probably not the alternator. Had good luck with Napa battery's over the years
RamCares
n/a
n/a
I apologize for the trouble, @Blandd. Should you address this any further with your dealer, please do not hesitate to follow up with us via private message for further support through that process!
Mark
RamCares
