BlakRose
Update, I got my Tazer yesterday and have been playing around with it learning how to use it. I can honestly say the Tazer is much better to use than trying to figure out what BCM changes to do. The Tazer simplifies everything to basically menu options on your instrument cluster. I contacted them today about the 8.4 SRT menu's and making them functional and I'll post when I hear something back.
In the meantime a few options I like so far using the Tazer (available for 2013+Ram)
1 - "Light Show" This can be easily activated with the key fob. You can use preset light settings or customize your own. I like this because instead of using the standard "Hazard" lights I can program all the lighting to do what I want when activated. This is much more effective than the standard "Hazard" light option especially if your on the side of the road for whatever reason.
2 - Engine and Transmission modes. These modes can be selected using the Tazer even though you can't access them using the 8.4 radio as of now. Currently I have my Ram's engine and transmission set to "Track" mode and OMG the difference in over all performance is amazing. Of course this can be further enhanced if you have HPTuners so you can modify the different engine and transmission settings in the tune. Note this applies to the 8speed transmission and not the 5speed. No I don't know what all the mode settings do as you have the options of (Track,Sport,Auto,ECO and another one). I just set both to "Track" and my Ram gets up and goes and shifts perfectly.
3 - "Line Lock" - While the Tazer is plugged in you can activate a line lock using two buttons on the steering wheel. I tried this today and it works great.....lol
4 - "ESP/Traction control" disable - While the Tazer is plugged in you can totally disable the ESP and Traction control in 2WD to have some fun like others in winter weather without having to worry about the ESP kicking in when your in 2WD mode. The only side effect is to disable this you need to turn the truck off and then back on again. You can totally disable the ESP/Traction in 4WD but you can't in 2WD.
There are many features the Tazer allows you too do and basically its a simplified and effective way to change BCM settings without the guess work as they have already done the work for you and narrowed it down to simple menu options. My only issue so far is every once and a while when making menu selections the Tazer would hang up and I'd have to shut my truck off and restart(power only, not engine running)
The Tazer for my 2016 Ram costed $250, I also already had my pcm unlocked through HPTuners so that was done and out of the way. For all the time I've spent trying to figure out different BCM settings to enable options using AlphaOBD I should have just purchased the Tazer to begin with. The one option though that AlphaOBD could do and the Tazer so far can't do is enable the trailer tow package which enables the factory trailer brake controller to work. I contacted them today as once I married the Tazer to my truck the brake controller no longer works.
Again I'll post with updates when I get them.......
