Engine replacement, will it work ?
Guzzwuz
Taunton Somerset UK
Hi, I’ve got a 2009 5.7 Hemi with a bad engine, I’ve got the chance of a 2018 5.7 Hemi with low miles, will this engine work with my 2009 engine management?
Thanks.
Brandon-w
Yukon
2015 Ram 1500
I'd look into it see if the reluctor wheel on the crank and cam make sure that's even compatable I think the mds system is different as well.
I wana say no for some reason. If it was a 2011+ I think it'd work but 09 is a different era as far as I know. Don't think it's crossable.
savage_46
Alaska
6.4 swapped
I don't think it would work as is. I've heard the same as what Brandon said. The crankshafts are different part numbers. I believe the MDS solenoids are shorter & use a different style connector. That part is not as big of a deal as the crank though. You might be able to swap out the tone wheel
