It would be since the 4.7 became fly by wire (like the hemi) in 2008. You could custom tune the 4.7 PCM with the 5.7 parameters, but you most likely couldn't successfully load an actual 5.7 flash into that PCM.I would think engine mounts will be the easiest part of that swap. Can you write a 5.7 calibration into a 4.7 PCM? A 5.7 from a same year donor truck with the harness and PCM might be considerably easier.
Pretty pistons.Your lost brother. Two maybe three things need changed. First is toner ring which comes w stroker kit. 32 teeth same as,4.7
.second is cam position sensor ring.
.and last may be throttle body.
My computer don't know it's running a 5.7 or a 4.7 or 6.1. it only knows what the sensor tells it. So let us f my crankshaft n camshaft sensor rings are same in 5.7 and 4.7 problem solved
.my tuner and computer guy handle the A/F
.ratios.
.keep believing you need to change wiring harness while I'm tearing up the streets of Detroit picking up chicks.
Sent from my S60 using Tapatalk
EVERYTHING is possible with enough money lolAnd when in doubt all problems can be solved with dollars.
No worries to the haters who think I will not follow through here. I like lames who tell me I can't do something. I'm doing my homework n measuring twice before cutting...the **** talkers should do same.
Remember there are three types of people in this world, those who make **** happen, those who watch **** happen, and those who wonder what the **** just happened.
I suspect the anti ****** guy above is of the latter type who marries the ****** I the end.
Stay tuned as I do have a day job tearing out city streets and sidewalks in Detroit that pays for my parts so this will take a month or so to complete.
Sent from my S60 using Tapatalk[/QUOTE
Them 4.7 guys are just something else aren’t they?Pretty pistons.
*you're
*"so let us f my crankshaft n camshaft?
Yes, I'm sure Detroit chicks will be all over your 52yr old ass in your beater 3rd gen Ram lol. Maybe the hookers....
I look forward to seeing lots of pics on this. I hold no illusion that there actually will be any of any real substance LMAO, especially dealing with your PCM, but I hope there are, all the way to the unlikely finished result.![]()
