Error code 0237 Boost pressure low
eastbayboy
Cummins diesal 24 valve
I started getting a 0237 error code and engine maintenance light. After doing some reading I am getting that the 0237 actually relates to a possible bad MAP sensor. But there is a 0107 code which is MAP Sensor Low.
Any thoughts on this error code?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
I'd need the full code, i'm guessing its p0237, but with the Cummins you never know.
I can give you my opinion based on working on the Cummins in the semis (they are basically the same engines) but you might be served better by asking in the Cummins section.
E
eastbayboy
The error code is a P0237. I found the Cummins forum and will try the question there. Thanks!!
