yesDid they do a load test on the battery?
Light weight jumper cables or a weak connection can cause a jump to not work or take a while to work. If you can’t get it to crank or even click on its own it’s usually a bad connection, either at the battery or wherever the positive and negative cables are connected. I’d bet it’s the ground.After my 2012 Ram 1500 sat all day Sunday in the garage, I went to start it this morning and nothing. No clicking, dead. Also, it wouldn't let me remove the key. Hooked up jumper cables to the wife's car and got some clicking but not enough juice to turn it over. Even the light under the hood was dim. Waited a bit still connected to the and it fired right up. Went straight to Les Schwab thinking my battery was bad. They tested it and the battery and alternator are good.
So, I have electrical issue. Any ideas before I take it to the dealer?
Thanks
