jsteinm1
- Oct 26, 2012
- 399
- 97
- Location
- Nebraska
- 2014 Ram 1500 Sport CC
- HEMI 5.7L
One more thing to add to the install:
The bolt holes on the dump pipe's flange did not line up with the Magnaflow cutouts holes. So I cut the holes on the QTP flange open (see pic), but I didn't feel good about that, because it seemed like that flange became a weak part in the set up and the heat might bow it and cause it to come loose...
Today, I took the cover that came with the MF cutout (see pic) and used a hole saw to drill a 3" hole (see pic), I filed it down nice and smooth and replaced the QTP flange with the my home made flange. Now I feel much better.
Oh, and I also replaced the wing nuts with regular nuts, because wing nuts are ***, j/k!
I'm planning on running this exact same setup sometime so I'm curious...The QTP dump pipe didn't line up, but the QTP Cutout did line up to the Magnaflow pipe? Or did you have to mod the QTP cutout also?
EDIT: Read back a couple of posts and i see it looks like the cutout flange is slotted so it fit but the dump pipe was not, correct?
I also saw that it takes 5 seconds to open/close the cutout. I figured they would have that on single push to go full open or full closed. I can help come up with a simple mod to make it that way when I do mine, I can let you know the details if you'd like. My goal if I can is to make my last unused Aux button functional for the cutout. I remember seeing a thread where someone was able to mod the unused ones in the 09-12 aux panel, hoping it will work on the 13+ also.
Also bookmarked this thread, tons of great info. Thanks for positing all of it!
