Exhaust Systems 101
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
I see a lot of exhaust questions on this forum and wanted to share what I learned. These articles cover back pressure, Scavenging, pipe size, pipe length and pressure waves all that goes into the complexities of the exhaust system. This is hours of reading but if you want the best out of your exhaust system this is a good start. And hopefully you will make the right exhaust decision the first time and save some $$$.
exhaustbackpressure
Exhaust: The straight scoop on backpressure | DSMtuners
Exhaust Theory | NSX Prime
Performance and road car exhaust
Technical Articles
EndTuning - Exhaust Systems
Exhaust Tuning Theory and System Design - Technical Articles & Reviews - Sideways Technologies
Exhaust length affecting power output ? - Forum - F1technical.net
Page 7
Exhaust System Technology: Science and Implementation of High Performance Exhaust Systems
kontrolled
2014 Ram 1500 Express QC
bump for awarness and general good knowledge.
jsteinm1
Nebraska
2014 Ram 1500 Sport CC
HEMI 5.7L
Whoa, thanks for posting up all the info! Exhaust systems are definitely complex. I got into engine design a little bit during my mech engineer undergrad work but I definitely don't know/remember all the concepts.
HammerHead
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Thanks guys. I cut into my exhaust system a few months ago and lost some low end and was determined to understand why. After hours of research and hours of reading I was amazed at how complex exhaust systems are. What I learned was priceless and if I had know what I know now I could have saved myself some money.
So many threads and questions about exhaust systems on the forum I wanted to consolidate my findings and hopefully help a fellow member make a good decision the first time and save some $$$ :favorites13:
14hemiexpress
6.4l
I love the garden hose analogy because is something we all know and have done it puts velocity into perspective on how smaller pipes can acually remove exhuast gasses more effectively.
I use to be one of the guys that used the term back pressure and was called out on it and looked into it more and realised I was WR wr wr wro wron wrong... Damn that's hard to say! It's one of things that there is a lot more to it than meets the eye.
Lots of good Info for anyone looking into exhaust systems. Thank you for taking the time to post it up!
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
So that being said Hammer what do you or would you run on your rig?
sicmadek
Banned
ponchatoula,la
2014 express qc
Go fill a bucket up using your finger on the hose then fill it with no retriction. Tell me which one fills faster. Restriction causes the water to shoot farther but can have a less flow rate.
gunner1374
In the 405!!!
HEMI 5.7
I too lost a little low end with my dual exhaust set up, but I feel that it now hooks easier and the power up top makes up for any loss on the bottom. Lots of low end tq is good for smokey burnouts or for vehicles with posi and wide slicks, but, IMO, not much good on a heavy truck on stock-ish tires trying to get out of the hole. I much prefer being able to hook a little better, having the power to spin for a sec on the 1-2 shift at 55-60 mph, and pulls like a beast in the upper RPMs. Also, an upgraded torque converter gets you over the low end anyway so who cares? Very good info though. Thanks for taking the time to help inform others. That's what makes this site great!
HammerHead
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
That's a hard question for me to answer at this point because I'm not sure how far I'm going to modify my truck. I got what I lost back with a custom tune so I'm just going to leave it for now. I want to get some track time in before I decide.
14hemiexpress
6.4l
Couple things 1 it can slow down just depends on how hard you hold your thumb over it. Second that speed creates a vacume as a engine doesn't produce a solid stream of exhaust it's pulses and the first one can actually pull the second out so on and so forth "it's called scavenging" 3rd smaller isn't always better there is a point were too small will cause problems there is a sweet spot depending on what rpm your trying to produce power but it's normally smaller than most people think it will be.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Building a proper exhaust is all relative to how you set the rest of the truck up. From all our testing at the track and dyno, we have always shown to get better peak hp numbers and better track times with an open 3" single exhaust on N/A Hemi trucks.
Our shop truck is running 1 7/8" headers with no cats, and no muffler or piping behind the Y-pipe. It doesn't get much more open than that, but when paired up with 4.10s and a 3400 stall converter, it still comes off the line hard with consistent mid 1.6 60' times.
Modifying a vehicle is a package deal, so you really want to have a goal in mind before starting any mods. I have learned this the hard way on previous vehicles and wasted a lot of money buying parts twice.
Hemi8073
Is like to see you run torque tubes matt, about 18-20" long and see how it affects you time/power on the dyno and at the track
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
When I decide to finally trailer the truck, I will switch to tq tubes. Its already enough of a hassle to swap wheels, remove muffler, and install track intake when I get there. The current setup is working well, but I do think it would pick up a little top end power with the tubes.
Hemi8073
I agree, it's the only reason I haven't done it yet, I just ordered the stuff to build them and will be running them at mopars at motorplex. Gonna go with dual 3" tq tubes about 20" or so, haven't decided on the length yet. I think it will pick up top end as well
HammerHead
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Yes sir, I Mis-understood back pressure of scavenging also. I was getting ready to cut into my exhaust system for the second time but figured I would do some research first. And I am very glad I did.
+1...
Yep, exhaust systems are defiantly application specific and you Must have a goal for what your trying to accomplish. :favorites13:
sicmadek
Banned
ponchatoula,la
2014 express qc
Just saying the garden hose isnt the best analogy. Fluid vs gas apples vs oranges
hemihustlin
Lower Southwest Quebec
And that at high rpms the scavenging effect is reduced because the pulses are coming so fast its almost like a constant flow.
Pulled from the second link
This (scavenging) has the most effect when there's a bunch of time between pulses...in other words, at low rpm. As the revs rise, the pulsed flow becomes more and more like constant flow, and the scavenging effect is diminished.
So, at low rpm I need a small pipe to maximize scavenging, and at high rpm I need a big pipe to minimize pressure drop. My exhaust pipe can only be one size, so it's a compromise. For a given engine, one pipe diameter will make the most overall power (i.e., have the largest area under the curve on a dyno chart).
14hemiexpress
6.4l
That's why long tubes normally lose on the low end but pick up on the top end.
KAKA
