I put a 2016 5.7 engine in a 2017 ram 1500, now with the key turned to the on position or when the engine is running the oil pressure stays at 100psi. Anyone experienced this ? Possibly a different oil pressure sensor between these 2 year engines?
Code PCM 0523.
Im having the same issues on my ram I have a 3.6 pentastar 2015 mine gets stuck on 98 psi or 99 psi I changed the switch already and even replaced my whole filter housing which came with a brand new one as well so basically I changed it out twice and still stuck at 99 psi
