Fender flares with adhesion, avoiding paint rub through?
Jtruck41983
USA
2016 Ram 1500 4wd
Are there any aftermarket fender flares that use the double sided 3m tape for adhesion versus just a rubber runner that eats through paint in a couple years? I heard of the protective tape that can be layed down, but seems it wouldn't be hard to just make a fender flare that adheres like the factory flares and solves the issue. Thanks
Pull Ya
Cedar Creek, Tx
My OEM flares have 3M two sided tape in addition to the screws. Lots of people put a 3M clear bra material around the wheel well opening before installing the flare so it won't rub on the paint.
Jay
J
Jtruck41983
USA
2016 Ram 1500 4wd
Yes, Im looking for wider fender flares with 3m tape, same at OEM but wider, and not needing to put the 3M protective material on..
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Ravjay12
Air Designs don’t rub your paint off!
J
Jtruck41983
USA
2016 Ram 1500 4wd
nice those look awesome!
Outdoors76
CT
i used OEM style with 3m tape and it still screwed my paint on fenders check my thread about them
Tray Burge
On the porch
Chicks must be crawling all over you then with a "dad bod" like that? bawhahahahahahaha
Weld them on and paint match, look into it. Even if you have tape that doesn't rub, that area collects dust and grime, no way around it.
