Few stupid questions...
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
Now, what are those tabs sticking out by my rear seats? Do they somehow fold down?
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
ANYTHING ON THOSE STRAPS BEHIND THE REAR SEATS?
KansasArt
Kansas
If you're referring to the vinyl handles pointing up from behind the seat, I believe that's for kids car seat. To hook the strap when the seat faces fwd. That's my best guess as the seat doesn't normaly fold down.
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
its on the top though
KansasArt
Kansas
Yeah, didn't phrase that well. They are towards the top of the seat. Behind the head rest.
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
Thank you. I'm gonna keep this thread open for answers to my stupid questions.
jacobsmudder
2014 1500 express 4x2 6at reg cab
I have a regular cab express with the manual rear window. When my truck is in defrost I can definitely hear air moving behind me, presumably over the rear window. Being a regular cab, it's right behind me so it's pretty noticeable.
tempotantrum
Iowa
The nylon tethers behind the rear seats are for child seats. Page 57 in the 2017 owners manual.
guyc66
Colorado Springs
I know, mine doesn't have that... Guess I don't have defrost! Lol
I would look in the Owner's Manual to see what cavity the rear defroster fuse (should be a 30 Amp Pink) is located in the Power Distribution Center (a.k.a. fuse box) and then check under the hood to see if you have one.....if so, then you have rear defrost. In my 2016 RAM 1500 Bighorn the rear defroster fuse is located in cavity F36. It's probably the only way to know for sure.....
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
I don't have the defrost wires going across the window bro
guyc66
Colorado Springs
My truck has rear defrost and I can't see the wires either. I'm not sure if they just have the wires running around the outside "non-visible" part of the glass or exactly how it works. Either way, my truck came with the 30 amp fuse in the rear defrost section of the fuse box and it works somehow. My rear defrost button is on the Uconnect 8.4 touchscreen and also on the dash panel faceplate.
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
That's what I thought but another guy on here stated thats for the side mirrors defrost
Flip-er
Raleigh, N.C
2013 Big Horn 4x4
the pull taps behind the rear seat head rests are for child safety seats, I have them and mine don't fold down
ColdCase
Thats right, that button turns on the mirror heaters. If you have a rear defroster option, it will also turn them on. Your build/option sheet should list it and you should see thin wires in the rear window, if you have it.
ColdCase
That may be the air moving up over the windshield, across the roof, and down the rear window, which one wouldn't notice in a longer cab or regular car.
Ricks Ram
Deleted
Sent from my SCH-I545 using Tapatalk
alphaprojects
