Fighting the rust
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Looking at a few products and wanted to see if anyone has used them for stop rust. I'm using it everywhere like internal door panels and the underbody of the truck
3m Rust Fighter
Boeshield T--9
CRC heavy duty rust
Or any other rust stopper in a spray can
Sitedrifter
I used 3M rustfighter (black spray paint) on lots of parts of my F150 and it seemed to work well.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I'm leaning toward the boeshield because it is not conduct and save to use around or on electrical like the window controls inside the door
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Navy Jelly.
Sent from my HTC One using Tapatalk
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Read up on that naval jelly and basicslly it disolves the rust but won't protect the metal afterwards... not exactly what I looking for
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
True...If your looking to encapsulate it or chemically stop it from rusting further you could also try Permatex Rust Treatment. This is an option if the metal has become too corroded but you don't want a hole in the body. It alters the rust (science stuff) and turns it into a hard metallic black surface.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Honestly I'm just looking for an undercoating product that is waxy and keep oxygen from getting to the rust so it will stop the rust
Merc225hp
NA
truck
gas
Research Loctite extends rust treatment. Good stuff but not cheap.
heus
2007 Quad Cab 4x4 Sport
Fluid Film is what you want then.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
That's what I thought untill I show that it "doesn't stick well if you ever was your undercarriage"
Sitedrifter
May be a professional undercoating would do the truck for you? I am looking into it myself.
