Pickles
- Feb 17, 2015
- 109
- 49
- Location
- Northern California
- 2015
- Hemi 5.7L
'15 Ram 1500 CC, Hemi, 3.21 gears, towing a CruiserRV Viewfinder Signature 28BHOB (figure a shade over 7K lbs loaded up)
First big tow was this last weekend - from just outside Sacramento to Tehachapi. Approx 700 miles round trip.
First thing - yes, this should probably be towed by a 3/4 ton, but my truck did the job fine and is within spec.
Second - the Ram felt great - or as good as can be expected. I mean, towing an almost 32' trailer behind you is going to cause some wind problems no matter what you drive (esp as a bumper pull), but there were zero "holy *****" moments on the 350 mile drive either to or from Tehachapi.
Third - I REALLY LOVE how this truck pulls on hills. From Bakersfield to Tehachapi is about 5000ft positive elevation change over 35ish miles, and this truck has the guts to pull it no problem.
Temps - At the highest, killing it coming up the hill, my temps were as follows
Coolant - 228F
Trans - 203F
Oil - 264F
This was at the end of 30miles, uphill.
Temps on normal towing (flat)
Coolant - 203F
Trans - 187F
Oil - 230F
Outside temp was min 89F, max 99F while towing.
Any thoughts that I should be looking at oil/trans coolers?
Coolant - 228F
Trans - 203F
Oil - 264F
Coolant - 203F
Trans - 187F
Oil - 230F
