jawzs2 so I went back into alpha obd to configure Car configuration change: Cabin Network: HSM Heated Seat Module: ' NOT SET ' -> '1 ' when I found the option it was just listed didn't say present and I went to select value either Set or Not set I chose Set then turned off the key and removed the Mx OBD connector but nothing changed. Once an option is selected to Set should it not show in the field of options as "present" I've seen that on other things I've added just not sure?
So you were able to enable the seat heat and ventilation module on. 2010What ODB connector are you using? I had no issues at all activating the heated seats and steering wheel on my 2010. I don't remember 100%, but I don't think there was a separate setting for the steering wheel, I only changed these two to "SET"
Car configuration change: Vehicle Config 1: Heated Seats Present: ' NOT SET ' -> '1 '
I’m trying to do the same on my 2012 what software and obd tool did you use
Thank you jawzs2 I was able to get my heat seat and ventilation module and memory seat module working with OBDLink MX and AlfaOBDI used AlfaOBD and an OBDLink MX
