Fluid leak
IJW84
I’ve been noticing fluid leaking from my left rear wheel hub and I thought it was from the brake caliper at first and after taking all apart, I see that the caliper piston looks ok and the leak may be diff fluid.
Can diff fluid actually come out from that area and what would need to be fixed or replaced??
SYKRAMMAN
Banned
Jersey shore
06 Mega
You need new seals and while your in there replace bearings also, they’re cheap. You will need a slide puller for the bearings that you can rent from most automotive stores.
IJW84
IJW84
Yep, there’s a bit of play when I wiggle hub around. And I just check my diff fluid level, it is low despite the fact I just changed the fluid two months ago and no leak around diff cover.
So bearings and seals it is.
Thanks for your response
IJW84
IJW84
Will I need an inner and an outer bearing and a race?
Also how do I tell if mine is a 9.25” or 10.5”
SYKRAMMAN
Banned
Jersey shore
06 Mega
Do you have a half ton or 3/4? You would just need the outer bearings n seals. If you have the 1500 then it’s a 9.25, if you have 2500, it’s the 10.5.
