Fluids changed
Fyredude
Edmonton
I just finished swapping out the fluids in the Front & Rear diffs, and the transfer case as well.
Since my vehicle is still under warranty, I decided to use all Mopar gear lube. The parts guy gave me a real good deal on all the fluids. It was just about as cheap as the aftermarket stuff.
It was all synthetic gear oil.
I'm glad it's all changed.
The rear diff was the dirtiest of the three.
Just have the transmission to do. Not sure when I'll do it.
Truck has 57000km on it.
R.L.K.
Bristol , Tn.
What type xsmn do you have Sir ?
Lots of good info & discussion on the 65RFE (6 speed auto) xsmn can be found here .
http://www.ramforum.com/showthread.php?p=1351574
Hope this helps and welcome to the forum Sir!
Sent from my SM-G900V using Tapatalk
