Yes, I have done it to my 2018 Tradesman. You'll need to purchase some harnesses from Mpgrimm2 here on the forum. That was a huge help in getting mine done. Of course you'll need the bumper with fog light holes and new light switch for the interior.I was wondering if anyone has put fog lights on a Tradesman, either OEM or aftermarket? Are the plugs there for easy installation? Just got a 2019 and was curious.
Thanks
Adding the fogs to a 2019 HD is different than the previous years. All 2019 HD tradesmans already have the correct bumper- just need to remove the solid bezels and install the fog bezels, brackets, and lights. There’s also three different styles of fog lights- round, long horizontal LEDs, and horizontal with the park assist sensors in the fog light bezels. The jumper harness is no longer plugged into a connector that comes from the front end connector under the fuse box. It’s now plugged into a connector by the driver side wheel well that carries the front park assist and fog light circuits. From there, the fog light wires go straight to the BCM, and the park assist wires go straight to the park assist module. I’m not sure if that connector would always be there to plug the jumper harness into. I would guess that if the truck has the rear park assist feature, it should be there. You still need the correct headlight switch, and a way to enable them.
So where do you get fog lights for a 2019 tradesman?
You wouldn’t happen to have a part number would you?
Dealer has several different part numbers for brackets, lights, bezels, but doesn't know which is which, WTF, I gave up, sent an email to FCA.
Ok thanksNo I never got a part number from them. If I end up getting them I'll post the part number.
The easiest way to get the correct part numbers for the type of fogs/bezels/brackets that you want is to search autotrader, and find a 2019 HD ram that has the fog lights you want. Copy the VIN of that truck, and PM Benny at allmoparparts, and he will tell you exactly what you need. His user name here is AllMoparParts.com.Dealer has several different part numbers for brackets, lights, bezels, but doesn't know which is which, WTF, I gave up, sent an email to FCA.
VIN of a truck with round halogen fogs. Bezels without park sense- 3C6UR4DJ5KG610614Dealer has several different part numbers for brackets, lights, bezels, but doesn't know which is which, WTF, I gave up, sent an email to FCA.
Before you buy the jumper harness, make sure the connector that it plugs into is present on your truck. Otherwise, you’re gonna have to make a custom harness, which will be cheaper than the jumper harness anyway.Round fog lights 68353533AA 2 required, Bezels 68449341AA comes with right/left, Brackets Right/left 68449383AA, I'm still looking for wiring harness part #
