Fog lights
alex_5_7
I've had this problem with fog lights. I've gone throught SO MANY hid kits and they always go out on my left side for some reason. I run a relay to the battery straight to the HID's ballast. I've changed the relay and the ballast several times and they always go out. Sometimes they don't turn on at all ( both) I'm so tired of this :( any of you recommend and kits?
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
weird that its only the left side. Physical mounts all solid? No heat source that might be killing your components? Electrically, starting from the start, where are you getting your "on" signal for the relay? Is it an accessory line power or constant on power with an inline switch? and is the 12V power out from the relay split between the lights from the same line? lastly, have you confirmed a solid ground for all lights? need more info
adurm
FL
2015 RCSB
Which relay are you using? If you are not using this one, that might be the problem: 2009-14 Dodge Ram HIDs - for Fog lights
The relay harness you need is the thing with the resistor packs. Email JJ at retroshop, he will help you for sure.
fdnj48
Central NJ
I have the Mopar specific Morimoto HID kit and it is all good so far
scotts2012ram
Ms
I'd say go with jj stuff a little more but man the customer service is out of this world. My relay box went out just a dud email him he needed a picture of a number on it sent me a new one. Can't ask for more then that I'll be back for shore
