What did you purchase and how did you mount it?
Check the thread above to see install pics, I bought it from MishimotoWhat did you purchase and how did you mount it?
Duh sorry...I was subscribed but I missed that.Check the thread above to see install pics, I bought it from Mishimoto
Sent from my SM-G965U using Tapatalk
I sent you the pics of the installation, check them out, but if you go up in this same post you'll be able to see themDuh sorry...I was subscribed but I missed that.
I was at 6373, and yes, it's actually plenty, but hopefully I'm catching at least a good amount of that before it turns into a nasty gunk inside my engine!!!Damn. What was the mileage when you changed it? 3oz. of oil seems to be a lot for only +/- 4000 miles. I would not have thought a new truck would have that much blow-by.
It's the 7.5 ounces from Mishimoto (Baffled)What type of catch can did u use or brand
That's a great location imo [emoji1303] you have gravity working for you in both directions [emoji16]Finally got my CC installed last week. Wanted to take more pictures but was running out of time. Hardest part was getting the original hose off and deciding where to mount the can.
I went with the Billet Tech can for the 3.6 Pentastar, not vehicle specific. Came with their fender mount bracket but I had no good place on the fender to mount it. I ended up drilling a hole in the bottom half of my airbox and securing it there. Put it in a good serviceable location where it's not too crowded.
I removed the intake tract from the TB and I did have some oil in the hose coming off the driver's side that connects before the TB. Tiny bit of oil had collected on the lowest portion of the elbow connector and TB itself. Considering a second can or trying to run both to the one can. Truck doesn't even have 3k miles on it yet.
Wow! I may need to bump this up on my to-do list for sure!Ok first dump and glad I checked it. Just under 300 miles since install and can was about half full. I drive 15 miles to work, idle it just enough to have rpms drop to normal and temps have been cold, into the negatives some.
I was pretty surprised how much was in the can. Truck has not even 3k miles. Glad I got this installed for sure.
Ok I am in the midst of doing this right now, I have a few questions.
1. The factory hose was a PITA to get off the valve itself. (I know, not a question)
2. Does anyone have a picture of the hose connection at the intake without the resonator on?
3. What has everyone done with the other hoses and wires that were clipped to the original hose to keep them from lying loose?
4. Not important unless I plan to permanently remove the resonator but where does the hose with the white clip on the resonator go? It was mentioned in an earlier post (#16) as if it went to the PCV valve but it doesn't.
