I didn't want to get into the CANBUS and didn't want to spend a ton of money for a front camera. I drilled two holes in the truck. One for the camera and one for a rocker switch. Power taps off of the front power outlet wiring under the console using a 2 amp fuse for the feed. Monitor is mounted with the adhesive pad.
I turned off the mirror image since it was for the front. Haven't decided on the grid lines yet so I have not cut that loop. If I decide to go with an interface to the 8.4 later everything is in place. I would just have to switch the video feed cable and pull the control voltage from the new harness.
