Front diff oil
mopar68
Wisconsin
I have a 2014 5.7Hemi outdoorsman and I would like to change the Front differential oil. However, the manual does not state how much oil it takes. Only the wt, can somebody please help me.
Atcer2018
Virginia
Get two quarts. The squeeze pack quarts are easier to use as you have more room to maneuver them around other stuff. The diff has a drain plug and a fill plug. Make sure you can remove the fill plug before draining or you’ll be up the creek without a paddle. After draining install the drain plug and fill via the fill port till the fluid barely dribbles out. Reinstall the fill plug and you’re done.
