Fuel injector brand?
aztsm
AZ
Pretty sure I have a fuel injector leaking on my 05 5.7. no code unfortunately. Thinking I’ll just replace them all. Is there a good brand that doesn’t break the bank for stock injectors? I see a lot under $100/set, but I’m sure they’re junk?
WillieBo55
Tulsa
So my 2014 is having a start up delay. I’ve read it could be the fuel pump, injectors, or a regulator on my fuel rail. Leaning towards the pump not holding proper pressure or leaky injectors. I’ll probably just replace pump and all 8 injectors. I read somewhere the original design sucks and the upgraded design isn’t specified as oem. Deatschwerks on Summit has multiple aftermarket options. Specifying flow rate at 42,50,60,72 and 95 lb/hr. I’m assuming the higher the # the more fuel it’s putting out. For a guy who isn’t planning on turbo or supercharger in the near future and is looking to upgrade his factory injectors. Which to choose? Maybe someone more knowledgeable will weigh in
