Gas tank swap
Rieggs
Minnesota
I'm hoping to do the 26 to 32 gallon swap in my 2019 1500 Classic. I saw a few others did this as well but I just wanted to confirm everything swaps over and I don't need any additional straps.
I found a tank on MyMoparPart.com, and the part # they show is 68323674AB. The price is $160. I was under the impression this would be more like $600+. Not complaining but I feel Like I'm missing something.
Thanks.
Administrator
It's just a giant blow moulded plastic container so not much expense. I'm guessing it come with them, but you'll definitely want to make sure it has the internal baffling. They are spring loaded plastic bag panel(s) that go inside the tank.
Rieggs
Rieggs
Minnesota
I'd love to do the Titan but that's a bit over budget. I'd just like a little more range.
Ohio5pt7
Ohio
Is the titan tank available for the 1500s?
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
crazykid1994
Last time I checked titan told me it is not rated for gasoline. Only diesel. And damn. If it’s only 160$ for that 32 gallon tank I may be all over it. I’ve been wanting to swap as well
Rieggs
Rieggs
Minnesota
It doesn't say anything about baffles. The description is pretty non-descript.
Here is the link to the tank. The sketch doesn't look right but the parts diagram looks accurate.
https://www.mymoparpart.com/p/Ram_2...-32-Gallon-Fuel-Tank/75661931/68323674AB.html
