If I read correctly the 4:10's are not a direct fit in the front on 2012+ models. RAM welded the gear on so it basically requires a either machining or a whole new carrier. I may have misunderstood but I seem to be hearing that anything other than stock gears for 2012+ 4x4's is costly due to this (no aftermarket options without machining). I'd be completely fine with 3.92's and lsd as I already have the 8sp which has a fairly good ratio on the first couple of gears to begin with.
Post #6 indicated the rear design was changed again so the prior year is not interchangable. However there is a thread on a guy doing 4.10 installed on his 2wd 2013.
Sent from my SCH-I405 using Tapatalk 2
