2015HD
So, I know the 2500 5.7 w/ 6 speed tends to require a little extra 'push' to downshift, always wants to hold that higher gear too long BUT, I've been noticing something I don't think is typical, wanted to see if anyone else has this problem.
I typically feather the gas as much as I can but lately I've noticed when I'm doing ~40 MPH and I start to go up a hill my truck will do a strange gear search until I press hard enough on the gas. I assume it's swapping gears because the RPM's change, it may swap 3 or 4 times (up / down) in the span of 3-4 seconds (or until I press hard on gas). This is all while running empty and not using tow / haul. Do I have an issue or is this typical?
