good to know a guy...
BeauDuke01
BeauDuke01
ok, last two till i get brackets finalized.
on the ground pics.
the codes
Houston, Tx
Magnum 5.2
dude great job! I tip my hat to you sir, the sport grille should really set it off
nitto
Lancaster Pa
1999 Dodge 2500
v10
awesome job man, wider tires would look pretty good
BeauDuke01
BeauDuke01
beeen lookin for a set of 08 20's. if i cant find some, ive been thinking about some '10 or '11 20" steel spares
Okiespaniel
Work, Shop, Computer
magnum, 5.9
The look is amazing!
If you can fll that gap under the grill with a metal strip it will look fine. The sport grille is oval on the bottom and won't flow well with the flat top of the bumper.
BeauDuke01
BeauDuke01
my little bro has access to a cnc plasma table at the offroad shop he frequents,so hes gonna cut me some brackets
NMRam
Estancia, NM
5.9 V8 360
Looks great......you could also use a LED light bar to fill the gap between the grille/lights and the new bumper. I agree the sport grille won't be right, so do something else unique!
Just a thought/question, with the brackets on the 4g bumper being offset the way they are, could you have swapped sides to have them sit wider apart without modification or would that not have worked? If this turns out fairly easy to do, I may have to give it a shot myself, so I figured I would ask.
BeauDuke01
BeauDuke01
the way the 4gen brackets are are proprietary to the side they are on, the bracket is contoured to fit the curve of the bumper. im thinking about some nice square driving lights to fit in the tow hook pockets, but haven't found what i want just yet.
BeauDuke01
BeauDuke01
well gentlemen, its done, permanently attached. a guy at the steel supply gave me a couple scrap pieces of 3/8" for free, and i went to town with my 3' cut off wheel and a hand drill...it took me 4 hours to cut out and drill the brackets. freakin nightmare with hand tools. next time i'll wait till the cnc machine at my little bros friends shop is fixed. my hands are killin me. gonna get a shower and tomorrow i'll run it through the car wash and get better pictures up. thanks for the support and patience. Beau
BeauDuke01
BeauDuke01
Well, looks like I will be selling my old front bumper after lunch, so I will be ordering a sport grill off fleabay here pretty quick
NMRam
Estancia, NM
5.9 V8 360
Turned out great!!! :peace: If you get a chance, would you mind getting some more photos showing how the sides line up, and what it looks like looking down from the grille? A shot of the brackets you fabbed would be cool also!
BeauDuke01
BeauDuke01
heres the bracket, crude as hell, but it works.
side shot
the front does have a gap between the grill and bumper, but the sport grill sticks out a bit more and should fill it in better
BeauDuke01
BeauDuke01
i used all factory mounting hardware on the bottom, and used 1/4" grade 8's to bolt on the bumper
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I like it
