Gotsa question.
tommyboi87
houma louisiana
5.2 Magnum
Ok. So when I turn the knob to switch between face vents defrost and so on, where does the signal go? My a/c is blowing out all vents and I have to fix it.
Sent from my SAMSUNG-SM-G925A using Tapatalk
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Bump bumpity bump bump bump...
JJP71584
Pgh, PA
Research a broken blend door...might be your issue
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Blend door is a heat issue, that isn't his issue. His issue is the modes.
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Go for the check valve in your engine bay first. Passenger side of the engine. Vacuum lines that go into the firewall. Provides the vacuum for the doors. That's most often the problem. It's common
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Vacuum line is probably the problem then. I have quite a few of them that are dry rotten.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Checked the lines under the hood, everything seemed fine. No leaks or collapsed areas. Next would probably be to check behind the dash. Or more simple solution, ignore the problem, right?
MagSport
South Carolina
If it's not a vacuum line, the check valves may be bad.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Any way to check it for damage or anything?
