HBS 2.5" level and PA 3" body lift install
ventoracing
ventoracing
Tucson, AZ
2025 Rebel 1500
STT
Ok, so a longer metal bar seemed to do the trick, broke all four body bolts loose on either side of the cab. Install of the body blocks on pass side went without a hitch.
Now I've got all four of the body bolts off on the driver side, but when I jack up the cab the whole truck is lifting off the jack stands...
Something is still holding the cab to the frame but I'm stumped...
A breaker bar under each mounting point tells me they are all loose.
Any ideas on what I might have missed?
sausec17
Banned
ATLANTA
hmmm, gotta be something strong enough to hold the frame to the body. Did you already disconnect the steering? I did that first on mine
ventoracing
ventoracing
Tucson, AZ
2025 Rebel 1500
STT
Ok, never mind. Must be my slightly off level work space. I just had to keep jacking and eventually the frame and the cab separated.
Cab body blocks installed!
ChloeBrooks
