HD Helper Bags?
RAM_Designs
Rockwall, TX
6.4L Hemi
Looking for some good helper bags for a 2016 2500 tradesman...just want to keep it from sagging so much when hauling a heavy load that might be too front loaded. I only have about 1.25" of rake at the moment, and with a heavy load last weekend it was noticeable lower in the rear...don't like that. Any help is appreciated, personal experience preferred.
mtofell
Firestone 5000s - have run them on 2 trucks and couldn't be happier. I can put thousands of pounds in the bed with almost no squat if desired. You can air them up from 0-100 psi depending on how much you need/want.
There are a couple of other brands that are very similar. My only advice is to stay away from the super-cheapie inside the coil type. From what I've read these are VERY minimal and not that much less $$. They may help for a 1/2 ton but with your HD go for the real deal.
MN-Ram
MN
6.4L Hemi
The Airlift 5000's are really nice too. If you get them with the internal jounce, they will also provide a spring bumper to help prevent you from bottoming out when the bag is deflated. They also have a lifetime warranty too.
If I need to add bags to my 3500, it will be the Airlift 5000's.
SwollenMonkey16
Definitely air lift 5000s. I've ran them on my 1500 and they are awesome. Will definitely be adding these to my 2500 if I don't upgrade the springs
reloaderguy
Oregon
2016 Power Wagon
Firestones with Daystar cradles. Or timbrens that you install when towing.
RAM_Designs
RAM_Designs
Rockwall, TX
6.4L Hemi
Why Daystar cradles? The short search I did of that setup says that the Daystar cradles don't totally fit the bags, that you need a little spacer.
RAM_Designs
RAM_Designs
Rockwall, TX
6.4L Hemi
What the hell do you guys put in the back of these trucks that require bags?
Batteries. Trailer full of batteries. Don't want it to squat in the back so I'd rather have some helper bags to keep it from sagging too much.
MN-Ram
MN
6.4L Hemi
If you contact SD Truck Springs, they will discuss the current suspension issues you are trying to remedy. When I reached out to them I was looking at 2 options that were $225-300, and the guy recommended a $89 alternative. I followed his recommendation, and was very happy with the result. That was on my half ton though. If I need anything for my 3500, I will go through SD Truck Springs and it will be the Airlift 5000's.
Whatever you go with, good luck.
reloaderguy
Oregon
2016 Power Wagon
Because you have to run a minimum 5psi in bags and it effects your unloaded ride quality. The cradles let's you push out all the air when not in use and the bags won't rip if you fully cycle the suspension. You don't need the spacer.
ocwill1
Severn, MD
5.7 eTorque
I had the airlift 5000 ultimate in my F150 and they were great. If you get the ultimate, you do not need to run any air in them when unloaded...
coobie
S.Michigan
2022 Ram 1500 big horn
Put a set of the Timbren suspension enhancement springs on my truck this past weekend.Bought them at E.trailer for $214 bucks.:)
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
That's what I was thinking. I put 1,450lbs. in the back of mine for work & by looking at it you couldn't tell I put anything in there. It did ride much better though.:happy107:
reloaderguy
Oregon
2016 Power Wagon
OP has Power Wagon rear springs, they have a lower carrying capacity. If you search Cummins Forum you will find this comes up frequently when guys run Carli or Thuren rear coils. The recommendation is generally airbags with Daystar cradles or Timbrens.
JLEONARD
Massachusetts
5.7L
I had Firestone Ride Rites in my 1500. Go with the 5000s for what your doing. Either brand, theyre the same.
mtofell
My wife
:joke: She only weighs 110#. She gets to ride up front.... and she NEVER reads this forum :favorites13:
MN-Ram
MN
6.4L Hemi
I had a 64-gun safe in the back of my 3500 SRW this past weekend, and you couldn't even tell it was carrying anything. Didn't change the ride any either. I don't think I'll need the airbags until the leaf Springs start to fatigue.
Maybe I'll just trade in the truck by then.
djse7en
