HD Lift and Tire Information
Rambojoe
Rambojoe
Indiana
Just wheels and tires. Saving up for some thirteen suspension parts, but that’s at least 2 years out.
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Armory 18x9 +12mm
Cooper Stt MAXX LT295/70R18
2016 Durango 5.7 AWD 3.07 Amsoil SS 5W-30
1996 Nissan Altima 2.4 Amsoil SS 5W-30
Not leveled? It looks pretty flat, I like it
AFMoulton
Nuevo Mexico
Nope, stock suspension for now........
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
What size 35's are those (width) They look narrower then normal 12.5 width in the pics.
They are 35x12.50s. I think the tire was right about 12 inches even, mounted and aired to around 55 PSI when I measured it a long time ago , the AEV wheels are 17x8.5.
mtnrider
Georgia
Thanks, they just looked narrower in the photo so was wondering if they were like a 285 width or something.
MADDOG
Out Exploring Arizona
Now we have a sticky. Keep posting up your info because I am sure it will help others.
My truck - 2.0" Tuff Country spacer level with shock relocation bracket, 18 x 9 Walker Evans Racing Legacy 504 wheels with +18mm offset, BFG KO2 35x12.50R18 tires
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
Laramie Power Wagons didn't come with decals. That's an old picture with full badges and door surround decals. Here it is with some of the badges off.
I have been following your Build on the Other Site. Very nice. Possible show a couple of Pics after your other additions.
reloaderguy
Oregon
2016 Power Wagon
I haven't done much to the suspension in a while so it pretty much looks unchanged. It's on 3"/1" Thuren springs, full 2.5" Kings, front Boogies Bumps, Thuren F/R trackbar, Thuren sway bar. Same wheels and tires as above (37x12.5R17 on 17x9 +18mm). The truck is about 1" taller in the front than a stock Power Wagon. The most recent changes are welded/trussed front axle, hydro assist, 5.13 gears, and airbags.
Rick Ram-jet
Big Bear Lake Ca
2016 2500 4x4 CC / LB
6.4 L
Not sure how to post pics from my cell ph....
2016 Big Horn, Hemi, Crew Cab, LB ...Thuren 3in system w/front/rear track bars, 2.5 King shocks, 35x12.5 Kanati Trail Hogs (work great in the snow and dirt trails here in Big Bear Lake) 20in factory wheels.
allenmp
Oklahoma
6.4 hemi
2017 Ram 2500
6.4 hemi
4x4 off road package
Stock suspension
Vision 18x8.5 0 offset rim
35x12.5x18
I wasn't sure they would fit and I found a guy close to me with these tires for $175 with good tread
So I figured that is a cheap way to find out if they will fit without level
With 5 adults in the cab at full lock if I hit a bump pretty good they will rub just a little bit
With 2 adults in the cab no rubbing at all
I do not want to level it but might do a small front level so when I load it down I don't have to worry
Idahoguy1984
San Diego, Ca
Cummins 6.7
I did a 6” BDS lift with Fox Shocks, dual fox steering stabilizer, fuel wheels with -24 offset and 37x12.50 Nitto Ridge Grapplers. Rides and looks great. Also full delete with 5” turbo back exhaust 7” tip, CTS2 monitor, Starlight Engine and Trans tuner. Next will be re-gearing.
Rambojoe
Rambojoe
Indiana
2017 Ram 2500
6.4 hemi
Stock suspension
35x12.5x18
Looks AWSOME!
Rambojoe
Rambojoe
Indiana
Idahoguy1984
San Diego, Ca
Cummins 6.7
That black truck looks killer!
Thanks I love it minus it’s a ***** to keep clean. I need to get the bushwaker fender flares to keep the water and dirt from getting grown up on the truck. And I’ve been debating if I should line x the entire truck and possibly wheels.
allenmp
Oklahoma
6.4 hemi
Damn that is a sweet truck
I had s black one and went to white
Couldn't keep it clean
Sure looked good for five minutes after wash though
Booner21
US
hemi 6.4
2in tuff country level. Tmi 535mb 20x9 -12 offset and cooper st maxx 35x12.5x20. MPG on the evic hasn't changed but I am scared to hand calculate. Ignorance is bliss.d79e3cbe6d1e2567254484f55b04a648.jpg015d1d9e1feea9b9572823eb4dd1703c.jpg9c68f2dd3c4a218f1b14f73295ca373d.jpg
Sent from my SM-G920V using Tapatalk
RoadRamblerNJ
Knoxville, TN
392 Hemi
2018 6.4 CCLB
2.5 RC front
1.5 Supreme rear
Solo delete
stock wheels/tires
The RC front did level it but it's so damn long that by the time you swiveled your head to see the rear you forgot and it looked lower so I had to add a little rake, kinda hard to see in this pick tho, the driveway has a good slope to it.
It's fun driving the longest damn truck RAM makes, ain't it? I'm driving the same thing, same color. Just not leveled yet. What's a Solo delete?
